2004 Dodge Ram Drivers Side Reverse Light Out
FOX_RACER627
  • 12 POSTS
Electrical problem
2004 Dodge Ram V8 Two Wheel Drive Automatic
I got the lamp out indicator about 3 days ago and found it was the drivers side reverse light on the tail light. I put a new bulb in and it wouldnt come on so i tried another bulb. Same thing hapened so i replaced all three bulbs (2 brake, 1 reverse) with new ones and it still wont come on. Checked all the fuses and all of them are good. What could it be?
Nov 27, 2008 at 1:06 PM
  • 75,988 POSTS
You probably have an open reverse light circuit between the bulb and the splice point where both lights to reverse meets-
Nov 27, 2008 at 3:01 PM
FOX_RACER627
  • 12 POSTS
Thanks for the feedback. How would I go about determining if I do?
Nov 28, 2008 at 3:19 PM
  • 75,988 POSTS
Trace the reverse wire to the splice point or run another wire and splice into the right rear reverse wire
Nov 29, 2008 at 2:30 AM
FOX_RACER627
  • 12 POSTS
Thanks for the help. I really appreciate it. Ill do it on my day off tommorow.
Nov 29, 2008 at 1:09 PM
