2004 Dodge Ram check gauges light
90,000 MILES • V8 • 4WD • AUTOMATIC
ARCHERYPRIMETIME
i have a 2004 ram when you start truck sometimes check gauges light stays on and oil pressure gauge doesnt go up shut truck off start again and everything is fine what causes this
Mar 13, 2009 at 4:21 PM
  • 110,251 POSTS
Hi:
If you don't hear knocking or ticking when the gauge doesn't go up, the oil pump is working. I would start by checking the oil sending unit. It is near the oil filter and sends a signal to the gauge. Make sure the connection is clean and tight and it isn't leaking. If everything looks good, chances are it is bad.
joe
Mar 13, 2009 at 4:41 PM
