2004 Dodge Ram check gauges light
ARCHERYPRIMETIME
  • 2004 DODGE RAM
  • V8
  • 4WD
  • 90,000 MILES
I have a 2004 ram when you start truck sometimes check gauges light stays on and oil pressure gauge doesnt go up shut truck off start again and everything is fine what causes this
Friday, March 13th, 2009 AT 11:21 PM
  • 109,885 POSTS
Hi:
If you don't hear knocking or ticking when the gauge doesn't go up, the oil pump is working. I would start by checking the oil sending unit. It is near the oil filter and sends a signal to the gauge. Make sure the connection is clean and tight and it isn't leaking. If everything looks good, chances are it is bad.
Friday, March 13th, 2009 AT 11:41 PM
