2004
45,000 MILES • V8 • 4WD • AUTOMATIC
CREWLSTEREX
When pulling away from a complete stop there is a humming noise which seems to be comming from the front untill speed is picked up then it disappears
Aug 17, 2008 at 2:46 PM
SERVICE WRITER
  • 9,123 POSTS
Really hard to say without hearing it, but I would first suspect the front differential as a guess.
ford? chevy? toyota?
1/2 ton, 3/4 ton? 1 ton?
You may need to get this up on a lift and run it.
Aug 17, 2008 at 10:00 PM
CREWLSTEREX
sorry I thought it would give you all that info since they asked for it when question was submitted
2004 dodge ram quad cab 1500 hemi engine 4x4
Aug 19, 2008 at 6:38 AM
SERVICE WRITER
  • 9,123 POSTS
Another thing to try, to help narrow this down is to have someone pass by you so you can try to determine if it is coming from a wheel or in the drivline. Still it probably needs to go on a lift. The differential would still be my suspicion, possibly the rear could be doing this as well.
Aug 31, 2008 at 2:15 AM
