2003 Dodge Ram wheel bearing hub replacement
140,000 MILES • V8 • 4WD • AUTOMATIC
PAT1125
when replacement of wheel hub right front do you need a special tools to get the hub out to replace with new
Oct 1, 2010 at 8:01 AM
BLACKOP555
  • 10,386 POSTS
if your replacing the hub assembly then no. just unbolt it and put in new one. mark the tie rods because if you dont youll need an alignment
Oct 2, 2010 at 6:40 AM
