2003 Dodge Ram turn signal
109,000 MILES • V8 • 4WD • AUTOMATIC
CJY
about 1/2 the time when i use my right turn signal nothing happens and when i use my left turn signal the right signal goes on. the other 1/2 of the time it works fine. is it a switch going bad or a fuse or the wiring. i replace the ignition wiring harness about 4 month ago if that matters.
thanks for your help.
Jul 16, 2010 at 1:17 AM
  • 110,248 POSTS
Honestly, it sounds like the wiring that was reciently replaced needs to be rechecked. Something is causing a short. If that checks out good, then have the signal switch checked.
Let me know what you find.
Jul 16, 2010 at 3:04 PM
