2003 Dodge Ram transmission fluid
2003 DODGE RAM
HALFPAPP
Transmission problem
2003 Dodge Ram Four Wheel Drive Automatic 69000 miles
I was under my truck this evening. I want to change the transmission fluid I cant find a drain plug how do I change this. Thank you.
Oct 16, 2008 at 1:03 PM
RENAUDTN
  • 636 POSTS
You have to unbolt the pan to drain your ATF... it's a messy job.
What I do, I drive my car on ramps, I start loosening all the bolt around the pan, then I carefully pry loose the back of the pan with a screwdriver(carefully, you don't want to bend the edge); since the car is inclined, the ATF will drip from the back of the pan.
Oct 17, 2008 at 8:33 AM
