2003 Dodge Ram trailer lights
2003 DODGE RAM
JUTPOWELL
Electrical problem
2003 Dodge Ram V8 Two Wheel Drive Automatic
i have an easy loader boat trailer and I can't get the turn lights to work with my truck. the parking lights only work. i checked all the fuses. do i need a taillinght converter? or is it something else
Oct 3, 2009 at 7:53 AM
  • 110,240 POSTS
Have they worked in the past? Are you using a factory connector? Have you checked for power to the vehicle connector?
Let me know if it has worked before, the type of connector (7 pin, 4 pin...). Also, if this is the first time you are hooking up, let me know that too. It may just be a matter of determing which wires on the trailer need to match up with the vehicle.
Also, using a battery charger, you can identify if the wiring to the lights is good. Let me know what you find or if you have other questions.
Oct 3, 2009 at 4:33 PM
