2003 Dodge Ram Throttle position on 5.7 hemi
70,000 MILES • V8 • 4WD • AUTOMATIC
HARDYS06
Driving at cruising speeds.. when i go to accelerate gradually nothing happens.. until i push the pedal abtou 1/2 an inch then it will downshift 2 gears and accelerate rapidly til i let off. this only happens at speeds above 40mph. i cleaned the throttle body and checked my air filter to make sure it wasnt any of them.. also the spark plugs and wires are good also. Where is the throttle position located? built into the Throttle body? anyway to check it to see if it is that.. also what else could it be..
Dec 12, 2009 at 11:46 AM
BLUELIGHTNIN6
  • 16,542 POSTS
throttle position sensor is located on the left side of the throttle body. Has the check engine light come on? Have you checked fuel pump pressure?
The TPS is on the throttle body.
Dec 13, 2009 at 8:32 AM
