2003 Dodge Ram The Blend Door
2003 DODGE RAM
75,000 MILES • V8 • 2WD • AUTOMATIC
MEMPHISPAINTS
When I turn on the heat or air - it's not blowing(Very Little)
The air recirc door will move from hot to cold
I can switch from defrost to floor to vent
I can hear the fan go from low to high
I just can't get hardly and air flow.
Mar 8, 2009 at 4:20 AM
RACEFAN966
  • 5,029 POSTS
So have you checked to see if this truck has a cabin air filter? If so and it is pluged then it will do this. Otherwise have you checked the air intake to make sure there is nothing in there that could slow or block air movement?
Mar 8, 2009 at 8:43 AM
