2003 Dodge Ram STARTING
64,000 MILES • 6 CYL • 2WD • MANUAL
MOPARMULE
i AM HAVING ISSUES STARTING MY TRUCK . RECENTLY SOMETIMES IT WONT CRANK SO IF I WIGGLE THE WIRES UNDER THE HOOD IN FRONT OF THE FUSE BOX AND BEHIND THE HEADLIGHTS IT WOULD START . NOW AFTER WIGGLEING WIRES IT WILL START BUT ONLY IF MY HEADLIGHTS ARE OFF.
I ALWAYS KNOW WHEN IT WOT START BECOUSE THE BRAKE LIGHT WILL NOT GO OFF AND MY LAMP OUT LIGHT AND SOMETIMES MY ABS LIGHT WILL ALSO STAY ON . IF I TURN ON MY HEADLIGHT THE ABS IGHT WILL COME ON WITHIN TWO SECONDS . THE ONLY LIGHT I HAVE IS THE FRONT PASSANGER HEAD LIGHT THE DRIVERSIDE HEADLIGH ND ALL TAIL LIGHTS AND SINGNALS ARE OUT . THIS ONLY HAPPENS WHE THIS STARING ISSUE GRIMLIN COMES TO VISIT . PLEASE HOW DO I FIX THIS
Nov 7, 2008 at 12:49 AM
BMRFIXIT
  • 19,053 POSTS
It sounds as loose, short, open, wires
need to open and investigate the wiring harness
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 7, 2008 at 12:19 PM
