2003 Dodge Ram power windows quit
70,000 MILES • 6 CYL • 2WD • MANUAL
JADE96
today drove to work no problems on way home i stopped at store rolled front 2 down partial and when i came out none would go up or down. All 4 power windows stopped working at the same time. all other electrical works like power mirrors, doors, and seats. i have already checked the fuse box under hood and relay what else could it be. also no switch in truck will work its own window, so no switch is working for any window from any door. please help ot is over 100 degrees here
Jul 14, 2009 at 1:19 PM
BUDDYCRAIGG
  • 2,262 POSTS
not much there to trouble shoot.
there is a blue wire coming out of the ignition switch that should be hot when the key is ON.
that goes to a 25amp circuit breaker, under the dash, near the steering column, taped to the harness.
and then power goes through a tan wire to the main door switch.
Maybe press the lock-out button on and off a few times.
Jul 15, 2009 at 12:34 PM
