2003 Dodge Ram MY FAN DOESN'T RUN FOR MY COOLING SYSTEM
2003 DODGE RAM
99,000 MILES • V8 • 4WD • AUTOMATIC
CJY
MY FAN QUIT WORKING W/O ANY WARNING SIGNS. MY GUESS IS I BLEW A FUSE. I CHECKED THE HVAC AND A/C FUSES UNDER THE HOOD AND THEY ARE FINE. I'M TOLD THERE 'MIGHT BE' A FUSE BOX IN THE CAB. IS THERE? IF SO, WHERE? I CAN'T FIND IT.
ANY OTHER FUSES TO CHECK TO CORRECT THIS PROBLEM?
Sep 23, 2009 at 3:03 PM
BMRFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 19,053 POSTS
Locate blower and unplug turn key on place switch on high check for power and for ground
you have both motor no good \
have ground no power suspect fuses ,wiring ,relay module and or ignition switch
have power no ground suspect and replace speed resister
check wiring
Sep 23, 2009 at 3:35 PM
CJY
thanks for your help. seeing if there was power was my next thought, but it seems so obvious the way it went out that it was just a fuse.
any idea what the most likely fuse # it could be if i do have power?
thanks again
Sep 24, 2009 at 8:31 AM
BMRFIXIT
  • 19,053 POSTS
Fuse # 4
and it run through the ignition switch and then to the blower motor DRK GRN wire
Sep 24, 2009 at 6:55 PM
