2003 Dodge Ram miss firing
65,000 MILES • V8 • 4WD • AUTOMATIC
X4G7Z9
miss firing,spitting,sputtering when accelerating after being fired up first thing in the day. mostly happens during rainy days or just after rain
Jan 20, 2010 at 6:21 AM
  • 75,988 POSTS
An engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Jan 20, 2010 at 11:57 AM
