2003 Dodge Ram ignitoin
2003 DODGE RAM
55,421 MILES • V8 • 2WD • AUTOMATIC
GOMER18
my ignition had lockied up on me latley. I went to start it after christmas and the ignition would not turn at all. i had good battery power, my gear shift was in park all the way, my steering wheel was loose, and my key would not turn. I also did not drive it for one whole day. i have not had any symptoms of my ignition cylinder going out. any ideas or thoughts
Dec 27, 2007 at 12:46 PM
BLACKOP555
  • 10,386 POSTS
try a different key. also spray the inside and outside of the tumbler with graphite lock lube and insert the key and try to wiggle it while spraying more. this usually gets the tumblers to pump down if they are froze up.
Dec 27, 2007 at 2:09 PM
