I have noticed that my truck has begun to start stalling?
94,563 MILES • V8 • 2WD • AUTOMATIC
WINFORDDJ
While stopping at a light, I have noticed that my truck has begun to start stalling or acting like it wants to stall. It is incredibly inconsistent however. Sometimes it will drive perfectly fine, more often then not when stopped for an extended period of time (2-4 minutes) it will drop RPMs and come close to stalling, but then catch itself. Occasionally it will stall, but if it does, it starts right back up. I have noticed that when it switches over to idle it gets alot quieter and just today I noticed that while normally it idles at 650 RPM, it stalled 3 times in 20 minutes (all at stop lights greater than 2 minutes) and occasionally idled closer to 900 RPM. I have B44K Fuel injector cleaner in there now and have not noticed a difference and it responds regularly when accelorating.
Aug 18, 2008 at 3:27 PM
2CARPRO JACK
  • 11,533 POSTS
Try cleaning the Idle Air Control Motor. Also clean out around the butterfly in the throttle bore with carb cleaner and a rag. This should help stabilize the idle.If it continues, you may have an Idle Air Control motor that is slow to react or shorting intermittently
Aug 19, 2008 at 12:55 AM
