2003 Dodge Ram Heat blows cold on driver side
125,000 MILES • V8 • 4WD • AUTOMATIC
SALMON77
When climate control is on heat, either on the floor or vent mode, it blows hot air on the passenger side and blows cool on the drivers side. When it is on defrost mode is the only time it blows equally warm air on both sides. The temp. control actuator is working and the actuator to change from defrost to floor vents is working too. I'm afraid its something deeper inside that I can't see I will have to take apart the entire dash board to figure it out. Help!
Nov 29, 2009 at 10:07 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Is system dual zone? if yes then drivers side blend door motor is not functioning. System is self diagnostic by use of DRBIII scanner but that means trip to dealer. Would save a lot of unnecessary work though.
Hope this helps
Dec 3, 2009 at 1:39 AM
