2003 Dodge Ram fuel problems causing car to run rough
45,000 MILES • V8 • 2WD • AUTOMATIC
UKDODGERAM1500
HI. I LIVE IN THE UK AND HAVE RECENTLEY PURCHASED A 2003 DODGE RAM 4.7 MAGNUM. HAVE ALWAYS WANTED A RAM BU HAS BEEN CAUSING ME PROBLEMS SINCE DAY ONE... PLEASE HELP!!!!!!!!!!!! WAS DRIVING ALONG WHEN ALL OF A SUDDEN THE ENGINE STARTS TO PLAY UP BIG TIME LIKE THE CAR IS GOING TO DIE THERE AND THEN. ROUGH IDLE AND RUNNING. HAD TRUCK CHECKED AND RANDOM CYLINDER MISFIRE DETECTED ACROSS ALL CYLINDERS. SINCE THEN HAVE REPACED COILS, FUEL INJECTORS SPARK PLUGS BUT STILL NOT RUNNING. STRANGLEY IT ALSO HAS LPG SYSTEM FITTED AND RUNS ABSOLUTLY FINE ON LPG AND THAT HAS BEEN CHECKED AND IS NOT THE CAUSE. ALSO SHOWING IS A FUEL TRIM OF 32% AND A MAP SENSOR WITH FUNNY READINGS. PLEASE CAN YOU HELP?
Sep 8, 2009 at 10:39 PM
  • 110,248 POSTS
Have you tried replacing the map sensor? If it isn't working properly, it could cause this.
Sep 12, 2009 at 11:48 AM
