2003 Dodge Ram Engine Oil
75,000 MILES • V8 • 4WD • AUTOMATIC
REVINEVAN37
I changed my oil last night. And when I took my Oil cap off I found a white residue that looked like go jo. It also looked like it had antifreezer in it and had a little bit of a smell of gas to it. What gasket or seal could be leaking for this to happen.
Dec 14, 2009 at 11:12 PM
  • 110,248 POSTS
That isn't uncommon during this time of year. Make sure the PCV valve is good and not plugged. Also, check the oil. If you have coolant in it and you are always adding coolant, you may have a head gasket problem.
Let me know what you find.
Dec 18, 2009 at 1:35 AM
