2003 Dodge Ram Engine Light
63,323 MILES • 6 CYL • 2WD • AUTOMATIC
JIMMY JACKSON
I went to two Autozone stores to get the engine light check out both stores said it the computer is reading low fuel leak, other words check the gas cap. So I bought a new gas cap and the engine light is still on. Autozone said it will take a while for the computer to reset for the engine light to go off. I also so online if you disconnect the positive terminal of the battery cable for 10 to 15 minutes it should reset it and the light will go off. Can someone please give me and answer before I have to take it to the dealership were they will charge me and arm and a leg. Thank you for to help. J.J.
Sep 25, 2008 at 12:19 AM
  • 75,988 POSTS
What is the OBD2 code/s?
Sep 25, 2008 at 12:23 AM
