2003 Dodge Ram Cooling
11,600 MILES • V8 • 2WD • AUTOMATIC
JBOY22
My air conditioner cools when the truck is at highway sppeds, however, it does not cool while the motor is at idle. The compressor cycles on and off every few seconds when at idle. I have tried recharging the coolant, but it does not seem to improve. What is my next step?
Jun 12, 2010 at 2:00 PM
BLACKOP555
  • 10,386 POSTS
compressor will cycle on and off if pressure is too high or too low in the system or if the evaporator core gets to cold and begins to ice.
chances are your pump is weak and only produces enough pressure to run ssytem at above idle.
you need a pressure guage set and a refr. machine to check whats going on
Jun 13, 2010 at 3:33 PM
