2003 Dodge Ram Check Engine Light
PAUL.PEP
2003 Dodge Ram V8 Two Wheel Drive Automatic
Check engine light was on, found and replaced cracked evap canister hosed. What is the procedure for getting my light to turn off, provided that I made the correct repair.
Sep 19, 2009 at 4:15 AM
SEAHUNTER
Had the same problem with my toyota. All I did was disconnect my battery for five or ten minutes and the check engine light went out. If the hose wasn't the problem the check engine light will come back on.
Sep 20, 2009 at 3:59 AM
