2003 Dodge Ram ABS AND BRAKE LIGHT ARE ON
90,000 MILES • V8 • 2WD • MANUAL
DSHRIDER1
IREPLACED THE FR. PADS AND THE ABS AND BRAKE LIGHT CAME ON AND HAVE STAYED ON. I HAVE CHECKED FUSES, FLUID LEVELS, AND OUTSIDE LIGHTS. THERE ARE NO WHEEL SENSORS ON THE FT. HUBS, AND THE REAR SPEED SENSOR HAS BEEN REPLACED. THE HYDROLIC SYSTEM WAS NOT OPENED. THE CALIPERS COLLAPSED SMOOTHLY AND THE BRAKES WORK OK UNDER NORMAL CONDITIONS.
Feb 3, 2009 at 6:12 AM
DOCFIXIT
  • 18,828 POSTS
Sometims light will pop on after pad replacement when you go to pump pedal that first couple times to contact rotor if key is on system senses failure. Go to Auto Zone have then pull code then erase that wiil turn light off.
Feb 3, 2009 at 6:21 AM
