2003 Dodge Ram abs
127,540 MILES • V8 • 2WD • AUTOMATIC
JMSIMPSON50
the wheel in my differential that has the magnet on it that sends the signal to the speed sensor has become damaged. when i first pulled the speed sensor out it was chipped up at the bottom by that wheel. how hard will it be for me to fix, and steps to do it right
Oct 27, 2009 at 6:07 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Exciter ring attached to carrier assembly for it to be offf that much to hit speed sensor your truck would not move. Chipping is common replace sensor. If exciter ring came off you would hear lots a noise in Diff. Is there a problem with ABS?
Let me know
Thanks for donate
Oct 27, 2009 at 7:14 AM
