2002 Dodge Ram won't idle
75,791 MILES • V8 • 2WD • AUTOMATIC
HOCKEYMOM18
Truck will not run uless you keep your foot on the gas. The first time it happened I thought I ran out of gas. The second time I stopped at a gas station to get a soda, came back out and it would not run unless I kept my foot on the gas. It took me 40 minutes to keep it running so I could go to work. Started right up after work. now it has been sitting in the driveway because I couldn't trust it to run. i went out today and it will not run at all unless you keep your foot on the gas. is it the idle control, fuel filter, or battery? any suggestions?
Thank you
Apr 25, 2010 at 5:23 AM
  • 110,248 POSTS
It could be a few things. First, check for vacuum leaks. If the check engine light has come on, then you need to have the computer scanned. To me it sounds like a bad throttle position sensor (TPS). But, I can't be sure without a code.
Let me know what you find.
Apr 26, 2010 at 1:46 AM
