2002 Dodge Ram Wont dive in 2 Wheel
80,000 MILES • V8 • 4WD • AUTOMATIC
SKTCON
My truck will not drive in two wheel but will run in 4 wheel drive. What is the problem and how do i fix it. Will it hurt to run the truck in 4 wheel for an extended period of time without it working in 2 wheel drive?
Dec 6, 2008 at 2:21 PM
  • 110,246 POSTS
HI:
You should never have it in 4X4 on dry surfaces. It will damage the unit. As far as the 2 whee drive is concerned, make sure the linkage to the transger case hasn't slipped not allowiing the truck to engauge into 2 wheel drive. If the linkage isn't going far enough, it sill seem like it is in neutral or you may hear gear grinding.
Let me know what you find.
Dec 8, 2008 at 5:34 AM
