2002 Dodge Ram uses water
67,000 MILES • V8 • 4WD • AUTOMATIC
KENNIE1
engine overheated. replaced water pump and thermostat. replaced fan clutch. using water but has no visible leaks. engine seems to run fine
Jan 26, 2010 at 12:24 PM
  • 110,251 POSTS
If there are no visible leaks, then a couple things could be happening. First, check the oil to make sure it isn't combining with the motor oil. Next, have you ever noticed white smoke from the exhaust?
Jan 26, 2010 at 12:35 PM
