engine overheated. replaced water pump and thermostat. replaced fan clutch. using water but has no visible leaks. engine seems to run fine
Jan 26, 2010 at 12:24 PM
✓Experienced Mechanic
If there are no visible leaks, then a couple things could be happening. First, check the oil to make sure it isn't combining with the motor oil. Next, have you ever noticed white smoke from the exhaust?
