2002 Dodge Ram TRUBLE SHOOTING
DWYATT007
Computer problem
2002 Dodge Ram V8 Two Wheel Drive Automatic 50'000 miles
My truck stopped running while on the road. Have taken it to a mechanic and they say the computed has failed and will require a new replacement.
I haven't heard of this being a problem.. Can you tell me how often this occurs, is there a record of computer problemswith the truck? I thought it might be the fuel pump.. But what do I know..
Sep 5, 2008 at 11:05 AM
BMRFIXIT
  • 19,053 POSTS
I think watching the videos on how to check for spark and fuel will help you
I would also try to get the codes if possible
as to answer if computer is a common problem I don’t believe it is
is your gone it need to be check
and from what I can sense from your question is that you don’t trust the shop your truck at
get another opinion have another tech take a look at it for you
i would check fuses relays ASD relay
crank sensor fuel pressure and fuel pump
good luck
Sep 5, 2008 at 10:28 PM
