2002 Dodge Ram Transmission fluid leaking from rear main se
2002 DODGE RAM
80,000 MILES • V8 • 4WD • AUTOMATIC
CLIFTONF
Just have U-Joints replaced and now tranny is leaking from rear main seal.
Dealer wants over $170 to replace this part plus another $200 for tranmission fluid and filter change.
I just can't pay them that much for such a simple job.
Can I change this seal myself easily ?
Do I need a special tool ?
Jan 4, 2010 at 1:53 AM
  • 110,244 POSTS
All I can say is WOW! ALmost 400.00 for a 2 dollar seal. Just remove the drive shaft, remove the old seal, then just simply tap a new one in. I always use a small piece of 2x4 to keep it flush and to it doesn't get damaged. Make sure to place a thin film of ATF on the rubber part of the seal before replacing the drive shaft.
If your trans fluid needs changed, let me know. It is a dirty but easy job.
Jan 8, 2010 at 3:59 PM
