2002 Dodge Ram Tranny 02 cummins
2002 DODGE RAM
52,000 MILES • 6 CYL • 4WD • AUTOMATIC
TOM2178
truck dies when you put in drive or reverse it feels like the torq converter is locked up when u stop with the truck in drive or reverse it wants to push and it bilds boost u let off the brake and it takes off.
If at a stop u put it in nutral it will rev up for a secend then go back to a normal idle I took it to the shop and thay cheked the computer and ther wase no codes thay sed to take it to a tranny shop.
it has a huse belet torq converter and shift ket
Nov 9, 2009 at 5:45 AM
RACEFAN966
  • 5,029 POSTS
It sounds like the torque converter is locking up now the question is why. This could be caused buy the throttle position sensor the lock up solinoid the TCM (transmision control module) or even the torque converter itself. I would have the TCM checked for codes this is different from the engine codes.
Nov 24, 2009 at 2:15 AM
