2002 Dodge Ram timing chains
GINGINTN
Engine Mechanical problem
2002 Dodge Ram V8 Two Wheel Drive Automatic
I cannot get my timing chains to line up before disassembly. Engine runs.
Aug 17, 2010 at 11:31 AM
WRENCHTECH
  • 20,760 POSTS
What engine do you have?
What are you doing to it?
Aug 17, 2010 at 11:53 AM
GINGINTN
working on a 4.7 timing chains. I can't get the old chains timing marks to line up before disassembly. The truck was running good before-hand. It is not out of time. It was having head gasket problems. Secondary chains were a little loose, was going to change them while I had it apart. I rotated the motor until I got worn out. Thanks for your help!
Aug 21, 2010 at 5:36 AM
WRENCHTECH
  • 20,760 POSTS
I don't know what to tell you except you may not be lining them up correctly.
Aug 21, 2010 at 6:33 AM
