Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Ram
Body
Mirror
2002 Dodge Ram Tighten side mirror
2002 DODGE RAM
185,000 MILES • 6 CYL • 2WD • AUTOMATIC
KMCELLIGOTT
MEMBER
My driver side mirror is loose and needs to be tightened. Can it be done
Apr 12, 2010 at 11:59 AM
Experienced Mechanic
You need to remove the door panel to access the bolts holding the assembly in place.
Apr 12, 2010 at 12:53 PM
KMCELLIGOTT
MEMBER
Thank you for your reply but you misunderstand. The actual mirror will not stay in position when adjusted. Can it be tightened?
Apr 12, 2010 at 1:35 PM
What stye mirror is it? Can you up load a picture of it? Is it electric?
Apr 12, 2010 at 1:56 PM
KMCELLIGOTT
MEMBER
I'll get back with you....Thanks
Apr 12, 2010 at 9:55 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
