2002 Dodge Ram tailights
103,919 MILES • V8 • 4WD • AUTOMATIC
STACEYGAVIN
My tailights wont go off, I have tried making sure dome lights and other lights off pulling fuses and nothing workes except pulling the battery positive off.
Oct 13, 2010 at 1:46 AM
JDL
  • 16,098 POSTS
Pulse the brake pedal, do they go out? If you pull fuse 34--10 amp located at the integrated power module, under the hood, that should kill the tail lamps.
You may need to check for applicable trouble codes? The headlamp switch sends a signal to the instrument cluster, the instrument cxluster sends a signal to the integrated power module. On request, the module grounds the parklamp relay. That relay sends voltage to the tail lamps.
Oct 13, 2010 at 2:34 AM
