2002 Dodge Ram radio
96,000 MILES • V8 • 4WD • AUTOMATIC
RAWCANDYMAN
how do you take the stock radio out of a 2002 ram 1500
Nov 15, 2008 at 6:17 AM
IMPALASS
  • 3,112 POSTS
Hello - This information is for: 2002 Dodge Truck RAM 1500 4WD Pickup V8-4.7L VIN N REMOVAL Disconnect and isolate the battery negative cable. Remove center instrument panel bezel.
https://images.2carpros.com/forum/automotive_pictures/248015_1_35.gif
Remove radio mounting screws. Disconnect electrical harness connector.
https://images.2carpros.com/forum/automotive_pictures/248015_2_53.jpg
Disconnect the antenna cable by pulling the locking antenna connector away from the radio (Fig.6) INSTALLATION Install antenna cable to radio. Connect electrical harness connector to radio. Install radio to instrument panel. Install instrument panel center bezel. Connect battery negative cable.
Nov 15, 2008 at 2:28 PM
