2002 Dodge Ram Radiator Leaks
85,000 MILES • V8 • 2WD • AUTOMATIC
AHAMAYALAN
I was driving back to work from lunch. When I pulled into the parking lot, I noticed a hissing sound. The front of my truck was steaming and hissing, and hot water was spraying all over. I thought it might be bad hoses, so I replaced the upper radiator hose, as well as the heater return hose. It is still leaking all over the driver side of the radiator. Do I need to replace it?
Mar 31, 2009 at 4:41 PM
CARADIODOC
  • 34,414 POSTS
Dry it off, fill it up, and watch where it's leaking from. If you don't see it leak right away, start the engine to warm it up and build pressure. A mechanic would pressurize it with a cooling system pressure tester.
caradiodoc
Mar 31, 2009 at 6:13 PM
