2002 Dodge Ram Power Steering Pump Leak
SK8INGFOOL1234
Steering problem
2002 Dodge Ram Four Wheel Drive Automatic 65000 miles
My 2002 ram 1500 4.7 magnums power steering has been weird for a couple of months. I never checked the fluid but yesterday i went to steer and the wheel wouldnt go without alot of force. I put P/S fluid in and i thought everything was fine, 10 minutes later the steering was dead. There is a leak on the P/S pump around the pulley shaft, do i need a new P/S pump with a reservoir or can i use my old reservoir with a new pump. Can i rebuild the P/S pump if neccisary? thank you very much
Travis Buckler
Feb 9, 2009 at 2:17 AM
  • 110,248 POSTS
Hi:
does the pump work when there is fluid in the it? Also, it's not worth rebuilding your pump for the cost of one. Also, yes you can use your reservoir.
Feb 10, 2009 at 9:57 AM
