2002 Dodge Ram power steering or heater core
72,000 MILES • V8 • 2WD • AUTOMATIC
JCHURCH8
i get no heat at idle... but heat at acceleration?
truck stalled when turning sharp and noticed fluid on front axles but am positive it isn't oil.?
Idles high or idles high at slowing down what could this be?
Feb 23, 2010 at 11:19 PM
  • 110,246 POSTS
First, is the coolant level full? What you described with the heater sounds like a low coolant issue. Let me know.
Now for the leak, does it smell like coolant? Have you had to add coolant or PS fluid?
As far as the idle, has the check engine light come on? Also, check for vacuum leaks.
Let me know what you find.
Feb 26, 2010 at 3:19 PM
