2002 Dodge Ram Pickup won't Idle
100,000 MILES • V8 • 2WD • AUTOMATIC
KERNAB
My pickup wouldn't start due to corrosion on the battery. I cleaned off the corrosion with coca cola and it started up. but now my pickup won't keep running unless i keep my foot on the gas and when i left off it immediately dies. what is the problem?
Feb 12, 2010 at 2:51 AM
JDL
  • 16,098 POSTS
Hi, Will it idle with slightly open throttle? If so, I'd clean the throttle-body. Check throttle-body sensors, where applicable. Check for trouble codes, some the national brand autostores used to check possible codes for free.
Feb 12, 2010 at 3:26 AM
