2002 Dodge Ram Not shifting properly
95,000 MILES • V8 • 4WD • AUTOMATIC
GIROUX
Often after stopping in normal driving, when taking off again the truck wants to start in 2nd gear. I'm able to manually down shift to 1st and manually up shift fine. This continues until I reset by shutting truck off and restarting. Can you please tell me what has failed?
Jan 30, 2009 at 4:28 PM
  • 75,988 POSTS
An engine needing a major tune-up will affect the operation of the transmission and a malfunctioning throttle position and vehicle speed sensor these sensors are used at times to indicate the throttle and governor pressures to the computer and in turn the comp. will command the transmission shifting solenoids to provide the upshift/downshift, overdrive, lock-up etc-
Jan 30, 2009 at 5:08 PM
