The heater / AC on the passanger side doesn't not blow I can feel cold air or hot air, but it's not blowing. The driver side blows fine.
Mar 17, 2009 at 8:43 AM
DON OLIVER
MEMBER
sounds like you either have a blend door stuck or the duct is not hooked up. if it blows on the drivers side, I would make sure the duct is hooked up. it sometimes get knocked loose when working in dash like a stereo install or heater blower repair. good luck
Mar 17, 2009 at 9:00 AM
RACEFAN966
✓Experienced Mechanic
If you need any help with tracing it down if the blend door looks ok get back to me and we will do a couple of tests. Let me know how it goes with the blend door and ducting and we will take it from there.
