2002 Dodge Ram no hot air
18,000 MILES • 6 CYL • 2WD • AUTOMATIC
TMALDON1
blower works fine, heater does not blow hot air.
Dec 17, 2007 at 7:00 AM
MERLIN2021
  • 17,250 POSTS
Try warming the Vehicle, then carefully feel the heater hoses, are they both hot? If one is cooler than the other, You need to flush the core, or a replacement job on the heater core. Also if the system has a heat control valve on the heater hose, make sure it is working!
The other possiblity is the blend door, work the temp knob, and try to observe the door to see if the servo is opening and closing it.
Dec 17, 2007 at 7:10 AM
