I just installed a New Thermostat, Water Pump, Radiator, Cap, and coolant.
The two radiator hoses both get hot, but there is no flow.
Thermostat verified opens and installed in correct direction. Engine warms up normally and does not overheat. Heater air seems mild, and not as hot as it should be.
Cooling system pressure guage holds at 12 psi.
Since they are the only cooling system parts left, heater core and bypass hose are suspected?
Any help is massively appreciated.
Sep 20, 2009 at 4:19 AM
