may go a few feet then stalls out?
185,000 MILES • V8 • 2WD • AUTOMATIC
HBARR71
in the mornings when I start up, she will idle fine in park, I can back out then put in drive, may go a few feet then stalls out. I just put in neutral, starts right back up then, no more problem for rest of day but goes right back to same in morning. what could this be? fuel filter perhaps?
Jun 7, 2010 at 3:39 AM
  • 75,988 POSTS
Check and test the idle air control motor and throttle position sensore
May 10, 2017 at 4:40 AM
HBARR71
thanx rasmataz..sorry just getting back to you but i cleaned the iac valve real good and also found that the hose from the air filter wasnt fully on at the bottom..fixed that and prob solved!!!
thanx again !!!!
