2002 Dodge Ram License light and parking lights not coming
MNIEF
Electrical problem
2002 Dodge Ram V8 Four Wheel Drive Manual
Was told by a dealer that it was a LCM "Lighting Control Modual" problem, and something may have gotten a surge. Isn't that what the cicuit breaker is for? and it would be around $500 then told it was not that.
Borther is a electical engineer he thinks it is a short or a switch.
Could this be nothing more then a switch problem?
Aug 31, 2009 at 5:59 AM
JDL
  • 16,098 POSTS
I'd check fuse 34--10amp in the integrated power module. With the lites on, that fuse should be hot, use a testlite. If it isn't hot, check the voltage circuits at the park lamp relay, use a testlite, two of those circuits should be hot all the time. Let us know what you find.
Mar 1, 2021 at 4:31 AM
MNIEF
Where would I find the the parking lamp relay? behind the peddle?
JDL
  • 16,098 POSTS
integrated power module, left front of engine compartment.
