2002 Dodge Ram Lamps Out
98,450 MILES • V8 • 2WD • AUTOMATIC
JIMENGN01
Driving home yesterday after buying a truck the Lamps Out waringin light came on and continued beeping the last 50 Milles home. Once I got home I found all running lights out and drivers side head light.
Brake lights work, bright lights work, turn signal lights work each indepentedntly but when I turn on the light switch nothin works but the passenger side head light. The error code I think was PO300 I Tried to confitm and it just tells me "done" I check all fuses
and swaped 2 50 amp relays. What is casuing this, I cannot drive this truck in this condition. Thank you in advance for yourt time
Jim
Oct 18, 2008 at 8:10 AM
  • 75,988 POSTS
Check fuse no.11 30amp, fuse no. 13 30amp, and the PTC no.5 7.5amp
Also Have the park lamp relay and the intergrated power module checked and tested
Oct 18, 2008 at 8:47 AM
JIMENGN01
Fuses start at #16. #'s 1-15 are relays, what is PTC
Thank you
Oct 18, 2008 at 8:56 AM
JIMENGN01
My appologies, # 11 & 13 are in fact fuses, they looked like small ice cube relays. I have checked both 11&13 and they are fine. Im not sure what you meant by ptc.5 7 .5. I am going to have to take it to the dealer and ahve the power mod checked correct. Is thisi a simple fix at the dealers ?
Oct 18, 2008 at 9:18 AM
  • 75,988 POSTS
Is thisi a simple fix at the dealers ?-Not really sure if it is a quick fix-never had to check that module.
Oct 18, 2008 at 10:00 AM
