2002 Dodge Ram heater problem
RAM GUY1
2002 Dodge Ram V8
i have a 2002 ram 1500,i have disconnected the heater lines to the firewall and have flushed the heater core till it ran freely and clear water.but i only have heat coming out the passenger side air vents,cool air comes out the drivers side?also i have a hint of ant freeze smell outside the truck after it runs for a while but no one can find a leak?
Nov 30, 2009 at 3:05 AM
  • 110,248 POSTS
The interior problem is most likely a result of a bad vacuum hose. The vents are actuated by engine vacuum. Chances are one of the vacuum hoses under the dash is either broken, disconnected, or cracked. As a result, the vent isn't allowing heat to make it to its destination.
Check for leaks. With the engine running, you may hear a hissing sound.
Let me know what you find.
Dec 4, 2009 at 2:52 AM
