2002 Dodge Ram Heater blowing cold!
165,000 MILES • V8 • 2WD • AUTOMATIC
CRAWDADDDY_69
Does the fan behind the radiator spin at a high rate at all times? Mine does and it concerns me. I did a flush of the cooling system and change the thermostat. Is it possible there is a blockage in the water lines preventing the coolent free flow? Or is it an electrical problem with the fan?
Dec 9, 2009 at 9:55 AM
  • 75,988 POSTS
The fan is programmed to cylcle on and off not all the time when a certain temperature is reach and controlled by the computer-check the coolant temperature sensor/engine temperature gauge switch and fan relay could be sticking
Dec 9, 2009 at 10:13 AM
