2002 Dodge Ram hearwe fan
62,000 MILES • V8 • 4WD • AUTOMATIC
CKELLEYKY
the heater fan just quit . we put in a new resistor and fuse, still no blowing air. anyone know what to do?
Feb 15, 2010 at 1:42 AM
JDL
  • 16,098 POSTS
Hi, I'd check for voltage and ground at the blower motor connector. If that checks out, suspect the blower motor.
Because voltage to blower motor goes hot with key on, gets voltage from ignition switch, sometimes the ignition switch connector will try to melt. There used to be a recall, if that is the problem? If you think that is the problem, talk to your local dealer.
Feb 15, 2010 at 2:14 AM
