2002 Dodge Ram headlights/talilights???
113,000 MILES • V8 • 4WD • AUTOMATIC
BADORSETT
I just removed and cleaned the negative battery cable as it was corroded. After I hooked it back up, the head lights come on when ever the key is on or it's running. They never did this before. Also, I can't switch to high beams, the high beam indicator on the dash works but the lights don't change. I have tail lights but the turn signals and brake lights don't work. This next one is a minor thing but the temp/direction overhead console works like it used to except the temperature shows two dashes and no numbers. HELP!!!!
Aug 30, 2008 at 4:41 AM
GARY BONE
Have you found the answer to this problem? I have the same symptoms and cant figure this out.
Driving me crazy
thanks
Gary
Oct 8, 2008 at 12:49 PM
